legolas
May 23, 2014Explorer
travelnutz wrote:
Jayco also makes an "A" frame quick folding insulated hardwall trailer 16'3" including the tongue to 22'4" long and weighs from 1915 to 2385 lbs and it's cheap to purchase here in the USA and Canada.
Sleeps 4 and has a dinette, fixed bed, countertops with sink and 17 gallons freshwater tank and 3 burner range top, drawers and storage, microwave, fiberglass sides and roof, window shades, 4" thick cushions even a 16,000 btu furnace with auto ignition, has standup walk around height when up, NO soft fabric sides or roof or anything on the ground to get wet, dirty, or mildew, spare tire and power roof vents, 4 corner jacks, 12V and 30 amp AC service, 11,500 btu A/C, and gets excellent fuel economy as it's only 62" high when folded down and going down the highways. Compact car very friendly and so easily towed with a little engine.
4 different models and can be manufactured with just the coach or with a large lockable storage box across the front or a rail fenced front porch for bikes, a grill, firewood, you name it. Lots of options and features not mentioned. GVWR is up to 4,150 lbs with 1260 to 1765 LB cargo carrying capacities. Makes a ultra cramped teardrop look beyond silly as it's not much larger than a teardrop but does so much more and all with the trailer and no need to load your tow vehicle full of stuff to haul it! A no brainer if small and very easy towing is what you want!
Sounds like a JAYCO commercial to me.....
