profdant139's avatar
profdant139
Explorer II
Nov 23, 2015
Glow Step Revolution: Pros & Cons (See Update in 1st Post)
(See update at end of this post. Bottom line -- don't loosen the scissor step bolts. See below for details.)
As you probably already know, Torklift contacted several folks and offered to send each of us a Glow Step Revolution (“GSR” – much shorter). They asked us to post our impressions of the product on rv.net, but (of course) they did not tell us what to say. Bottom line: this is a fairly “glowing” review (pun intended), but this product is not for everyone, as I will explain below. You can see more about the product here – I won’t repeat the stuff on the manufacturer’s website:
Glow Step site
The purpose of this posting is to help folks who are already interested in the GSR and who are trying to decide whether to order one. I posted a separate entry regarding installation on the Do It Yourself forum, assuming that you want to try to install it yourself (which I did). (I am going to try to cross-link the two discussions, but I am not sure that is possible.) Here is the link:
Installation tips and issues
So, here are the Pros: First, I think that the GSR is much safer than our original equipment steps were. There is no big gap to watch out for when going up or down. The stairs go all the way to the ground. We won’t need to tote along a step-stool, which is so often wobbly (especially when boondocking in rough terrain). The GSR steps are much steadier, since the legs rest right on the ground. (And the legs adjust to different heights, since the campsite always slopes up or down a little, and sometimes a lot.) Since the GSR provides you with three or four steps instead of two, each step is smaller, requiring less effort to balance safely (especially when carrying heavy loads in or out of the trailer).
Second, I think the GSR is a lot easier on the knees, ankles, and hips, which is a big deal for older campers (like me) – three smaller steps instead of two big ones. It would be easier for small children and small pets, too, but I do not have first-hand experience with that. I can also add that because my wife is vertically challenged (about 5 feet tall), she finds the GSR makes it easier to get in and out. That is especially true because our trailer is raised (due to an axle-flip) for boondocking and off-road travel, so there is a long way to climb.
Third, the GSR greatly reduces shaking inside the trailer when in use. There are two major benefits to this feature – it is less annoying to the folks inside the trailer. But more importantly, it cuts down on the progressive loosening of the stabilizers over time. Have you ever noticed that even if your trailer is pretty stable when you first set up, it gets less stable over a period of a couple of days? I think that’s because the stabilizers settle a little every time you go in and out of the trailer. The GSR really cuts down on that problem, in my opinion.
Fourth, the company did a great job with “fitment” -- they told me exactly what measurements to take, and the new steps slipped into place perfectly (with one exception – see the “cons,” below).
Fifth, the GSR is easier to deploy and retract than our original steps were. Those heavy steel steps were very balky and awkward. The GSR glides in and out – very slick. This is not a huge plus, but it is not trivial, either.
So now, the Cons: First, this unit costs a lot of money, even without paying for installation (discussed below). Is it worth it? The answer is “it depends.” If you have great knees and hips, and if your trailer is not raised, and if you don’t mind the shakes, and if you are on a budget, this product may not be worth it. But as you check off the various factors (aging legs, decent finances, a shaky trailer, a desire for greater safety, small pets), then the GSR becomes more of a necessity and less of a luxury item.
Second, the engineering of the steps is beautiful – a clever and intricate folding mechanism. Why is that a “con?” Because I am a little concerned that the sand and grit of boondocking will abrade the moving parts. Obviously, I will open up the steps and rinse them off after every trip, but still, it is a concern. It is too soon to tell if this will be an issue. Frankly, I have looked on the Internet for complaints about this, and I have found nothing, so this may be a non-issue. (I plan to add a mud flap behind my right tire, which is right in front of the door and the steps, to cut down on the mud and grit.)
Third, the installation was a lot of fun (I love working on my trailer!), but it was not effortless. I did it by myself – no helper – and I had to develop some work-arounds to lift it into place. (If you are interested in the details, see the Do It Yourself forum.) I had to drill through the metal step brackets on my trailer – that is a necessary part of the job. There was a lot of bending and kneeling and squatting, on less-than-wonderful legs (see above). I would say that unless you are both moderately fit and moderately handy, this is not a job that you want to do yourself. So that adds some cost, if you have it done at a dealership or by a mechanic.
Fourth, the design of the GSR makes the installation a little tougher than it should be. Without getting into too much detail, the heads of the rear pivot bolts protrude slightly from the sides of the step frame housing, so you have to make room for them by cutting into the metal brackets on your trailer. The instructions that come with the GSR say: “Side brackets vary by manufacturer, and may need to be trimmed to clear the hardware protruding through the sides of the GSR frame.” Measuring for that cut-out and drilling the hole in the bracket to accommodate the bolt heads was pretty tricky. (I searched for other people’s installation stories, and many of them mentioned this exact issue.)
The unit would be much easier to mount if the rear pivot pin were brazed, welded, or cast as part of the frame, rather than being secured by a bolt. Alternatively, the bolt head could be countersunk into the side of the frame, to avoid interfering with the brackets.
Until this minor issue is fixed, the installer has to be a moderately competent do-it-yourselfer or a professional. But if that obstacle were to be removed, almost anyone could install the GSR, thus expanding the market for the product. I say “almost anyone” because there are people who are not comfortable drilling through metal with a hand held drill motor, and holes must be drilled. Of course, the mounting holes on the GSR are not matched up with the existing holes on the mounting brackets on the trailer – there is no way that they can be matched up, since there are so many different bracket configurations. And the drilling has to be done with the brackets on the trailer – most brackets are welded on.
Given all the pros and cons, and knowing what I know now, would I have paid my own money to buy this unit? Yes, certainly. I might have had to persuade my wife that this was a good investment (she is very thrifty – thank goodness), but I think I could have done so. After all, if you take the cost of the GSR and amortize it over however many days of camping you expect to get out of your trailer, it comes out to pennies per day.
Anyway, that’s my review -- I hope you found it helpful, and I would be happy to answer any and all questions.
(Update -- during the course of the discussion below, someone suggested loosening the scissor bolts slightly, so that the whole assembly would deploy faster and easier. I thought that sounded like a good idea. There are 36 bolts secured by nylon-core locknuts. Almost all of the bolts and nuts are seven-sixteenths, with the exception of a couple of allen-wrench bolts. I carefully backed each one off by an eighth of a turn -- a tedious job, but not technically demanding. I then put the steps into the stored position and then tried to deploy them.
Well, they deployed real fast, but not easy -- the whole step assembly shot out of the frame, and the "landing gear" slammed onto the ground. No damage to the steps, my fingers, or my feet, but this is not good. I retightened the bolts, and the whole thing now glides sedately out of the frame into position, no drama, no damage.
Your mileage may vary -- maybe loosen them by a sixteenth of a turn? But I am going to leave well enough alone!)
  • I received a tracking number for my GSR. It shipped today. I'm ready.
  • I attached a cable tie to the pin and then fastened it to the release lever on the steps -- now, when I pull the pin and deploy the steps, the pin dangles from the cable tie and won't get lost. I often camp in deep dust or sand -- it would be easy to lose that locking pin if it dropped in the dirt!
  • I hook the pin on the swing out grab handle when not in use so i do not lose it. I also gota set for free, but I have a long history with Torklift and the fact I spend most of the year in Mexico is a great test for many of their products especially those involving suspension.
  • I too was contacted about a GSR and am excited about it. Based on what I have read and the previous posts here, I'm ready to receive it. I have provided pictures and measurements requested and was told just a few days ago they are finishing up on a mounting bracket and are waiting on it to be powder coated. Maybe this bracket will eliminate the drilling and cutting reported previously? I don't know, but I do hope so. If metal work is required I have a nephew that is a certified welder and he has agreed to do whatever is needed to install it. I also travel with a floor jack so that won't be a problem during install.
  • I received a similar offer of steps in exchange for a review. I had to have mine installed by an RV service dealer, though, as my original step box was welded to my frame. Since I don't have a torch or welding equipment, I needed professional help.
    That said, they did a great job, and I am very pleased with the Glow Step(s)! I opened them at the service shop, and there was an angle away from my trailer. The steps extended down to the ground without a large step from the trailer or onto the ground. Due to the height of my trailer, I have a 3-step configuration. I think this will work great off-road, which is where we do most of our camping. Having to raise the door-side (normally curb-side, but in the context of this discussion, for those who are not familiar with the 'curb-side' term I will use door-side) tire to get the trailer level, the additional step of adjustment will be crucial.
    When I got home, my gravel parking pad has a bit of an indent for the tire, so the door sits closer to the ground. I opened the steps, and the top step was almost flush with the trailer floor, which is not a problem. The other two steps deployed, and the stabilizer feet hit the ground just fine. Another perfect deployment.
    I had step carpet wraps on my old steps, so I put them onto the new steps. Due to the size of the carpet, it covered the "Glow" part of the steps. To keep the integrity of the Glow design, I folded-over the sides of the carpet to expose the Glow stickers. The stickers can now be seen. I'll know in 3 weeks if they are visible after dark, as I have a 2-night trip planned. Should keep the DW happy to be able to see some guidance at night.
    The adjustability of the step deployment is a big factor. ProfDan said the steps would be justified for old farts (the clan to which I belong), or short people (my wife's clan). While Dan also mentioned boondocking, I will say that, because of the varied terrain of boondocking, these steps are even more useful. I also carried an adjustable-height step pad, which we used every trip. Sometimes it was at its lowest height, sometimes its highest. I no longer need it! I can't foresee any need for more adjustment than what the Glow Step offers. Until I get out into more varied terrain, I won't know what the full range of use is, but it will be interesting to find out.
    A bit pricey? Yes, but so was my second battery. And my solar array. And my tongue jack. And my other modifications. I believe this will make our camping even more enjoyable, as it will be easier to get in and out of the trailer, with much more stability. No more rocking the trailer every time I come in and out.
    Regarding the cotter pin - it shouldn't be keeping the steps up by itself. It only keeps the latch in-place, so it will have minimal stress exerted on it, ever. My concern is that I will lose it at some point, if I get careless and don't put it back in the holes after deployment, which is not hard to do. Lazy is the only excuse for me to lose the pin.
    I would give the Glow Step Revolution two thumbs up!
  • I love mine. A buddy of mine who has a close connection with Torklift already bought up the cotter pin issue with them, and told me they are working on an integrated solution.
  • I will add that we also received the offer and took them up on it. Our installation required no drilling at all - it fit right into the holes that our old ones came out of. The only problem we had was holding the others up while unbolting them - our jack broke and we had to go find another one.
    Otherwise, ours are wonderful. My one concern was the lasting ability of the cotter pin that keeps the steps extended.
    I know they are working on some tweeks to their product, so we will see what they come up with.
