Lantley wrote:
kw/00 wrote:
Glad you stated all the so called facts... but not one size fits all, for u I’m glad. For others it doesn’t work that way. It is what it is... diesels are not the cure all but neither is gas. Again, I don’t buy into all the facts.... different markets, lots of variables and tons of so called experts everywhere.
The only advantage a gasser has over a diesel is cheaper initial cost.
ALL other performance factors will favor diesel.
I challenge you to point out a performance parameter that a gasser does better than a diesel.
Heat in the cab at -40*.
That was a concern for me when I switched to a gasser. I froze in both my previous diesels for 3 months of the year when it got really cold here in Canada. The diesels I had never made it to operating temperature on my morning commute when it got cold. That commute involved about 8 miles of highway followed by 15 or 25 minutes of city commuting. The diesel trucks would actually cool off when I got into the city. And, to add some additional info, the trucks had been plugged in, in an attached garage (not insulated or heated) and the grills were completely covered/blocked by a winter front.
So, for a guy (like me) who only tows a trailer 5-6 days out of 365 in a year, the gasser made far more sense.
The diesel mpg advantage has shrunk compared to what it used to be (gas became more efficient and diesel became less), the complexity of diesel and the emissions garbage they are saddled with has increased, and now you have to add, buy, and store DEF.
As to remote starting, that might work great in Florida when it's "cold", but anyone who has experienced -40* and a diesel truck will tell you if you leave a diesel idling at -20*C or colder, the engine coolant actually gets colder as they idle. They just don't use enough fuel while idling to stay at operating temp.
We can all agree I think on the fact that when you use "towing performance" (mpg and how well it pulls) as your only metric to judge a 2500 or 3500 truck by, diesel wins hands down. There's just no denying that 900+ lbs-ft of torque beats 450 lbs-ft.
But for me, when everything was considered, gas was a much better choice.
