GeoBoy
Apr 09, 2014Explorer
I added a Tru-Cool 40K and just ran rubber transmission rated hose from the radiator to the cooler and then rubber transmission hose from the cooler to the return line going back to the transmission. I took a die grinder with a cut off wheel and cut the metal crimp on the factory lines, where the rubber hoses are and you will find a ferrel that you can just put the rubber line, with clamps, on to and from the cooler.
