msmith1_wa
Mar 24, 2015Explorer
I have an 03 2500HD with the 8.1 and Allison. The Allison is the only auto trans that was installed in trucks with th 8.1. As was previously stated the Sub and Avalanche did not get the Allison because it did not fit. The rear axle in the 8.1 trucks is different than the 6.0 trucks. It has a larger ring and pinion and is the same as is used in the Dmax trucks.
I have mostly towed a 10,000lb gross toyhauler with a quad in the bed also. No trouble maintaining speed when towing even on hills.
