jmp
Mar 25, 2015Explorer
Brisk wrote:jmp wrote:
I have a 2003 GMC with the 8.1/Allison w 4.10 ratio with 37k miles (extra cab) towing similar weight. It tows 12-13k with ease...you just use more gas on the hills! I could not imagine a 6.0l, regardless of trans, towing this amount of weight. Keep looking for the 8.1. They are out there.
That is good info to have. Thank you. Can you run in OD on the flats pretty easily?
Yes, it will tow in OD on flat ground especially when empty. It will pop out of OD on moderate inclines though. If you can find an 06-07 with the Allison 6-speed, that would be ideal. It is thirsty though even when not towing but I don't care since the motor is bulletproof.
