calewjohnson's avatar
calewjohnson
GM Brake Lines
Well, my brake lines finally broke (major corrosion - I am sure the fuel lines are next). I had new rubber put on the truck yesterday, got a call saying that I had a brake line leak. They left it on the lift until I got there, so I could take a look. It all looks pretty bad. They suggested I take it to the dealer, since there is no telling what else may need to be replaced. I think I am going to go ahead and have all the lines replaced, for peace of mind, considering we just came over Tioga Pass a month ago....
Question, I am in CA (not registered), has anyone had a dealer do work on their TV that was obviously lacking emissions equipment? I have used my dealer in FL, I don't think it ever crossed their mind, however, being in CA, I am thinking it is a little different out here. I am envisioning them saying they will replace my brake lines as requested, then quote me for a CAT/EGR install also.... Thanks,
Cale
  • If you are planning to keep the truck a long time, there are stainless steel brake line kits available.
    Cale
    Don't worry about the dealer wanting to put a Cat/EGR or whatever on. It's not that bad..............yet. :W It would be a different story if your truck was under warrantee and your engine blew up with a tune on it.
    Hope you get it fixed soon.
    Thanks, I am sure I will find out tomorrow, going to try to get it in early...
  • wgriswold wrote:
    I recently read an article about a potential recall of large trucks and SUVs for rusting break lines. GM was resisting the recall. Perhaps there is a secret program to help owners. It can't hurt to ask.
    Wow, a quick Google of that gives a lot of info. At least if I have it repaired at the dealer and a potential recall were to kick off, it would all be documented. What sucks, or is good - depending on your view, I have no brakes. The folks that found the brake leak let me take it home, I don't think I will be driving it to the dealer though, I had a couple oh******moments heading to the house.
    Cale
  • I recently read an article about a potential recall of large trucks and SUVs for rusting break lines. GM was resisting the recall. Perhaps there is a secret program to help owners. It can't hurt to ask.
    Cale
