Engineer9860 wrote:
ScottG wrote:
Veebyes wrote:
Can I have a Cummins with an Allison tranny, Chevy ride & maybe Ford interior?
2WD dually would be fine since I am a summer driver & always carry a tow rope so that some big bad guy with his 4X4 can tow me out should I get stuck once every 100,000 miles or so.
You haven't looked at new truck recently have you!
You don't wan't the Ally behind a Cummins. Both the Ford and Ram have better trans - they just don't have a "name". But they're both stronger and more positive shifting and use much more modern technology.
Interiors and suspensions have changed a lot too.
Do you want to back that up with some facts?
How about the Ram/Aisin tranny is new, and hasn't built a long term reputation. Ya' feelin' lucky? Signing up to be the beta tester?
The Allison does have a long reputation and it is an excellent one.
Aisin has been around many years, and the
Ram chassis cab has the Aisin starting 2007.5 models.
http://www.aisin.com/profile/history/http://www.allpar.com/mopar/transmissions/aisin.html"In 2013, Ram switched to the more robust AS69RC automatic, which also had some control changes for greater durability, and extended availability to the Ram 3500 pickup; Ram also claimed a 1% gain in transmission efficiency, with better driveability. Once again, the Aisin transmission was only available with diesel engines (though it was now standard on some high performance diesels); Ram introduced a dual transmission cooler setup at the same time, along with a transmission fluid heating system. The AS69RC has three planetary gear-sets, one over-running clutch, and full electronic control over shifting and the torque converter clutch."
It is $2900 option that I would gladly include in a new truck order.
One has to also realize with any of these new vehicles you are much more closely tethered to the manufacturers service department. Remember the old saying "phone home"!
Chris
