Sturgeon-PhishExplorerJun 03, 2015GM Pump Rub in Transfer CaseGM transfer cases 261 and 263 are prone to a condition known as Pump Rub. It is where the pump used to circulate the fluid in the transfer case wiggles back and forth wearing a hole in the transfer c...Show More
1oldtruckExplorerJun 03, 2015Where did you find a new housing? My brother has the same problem and all he has been able to locate are entire transfer cases.
Related ContentTransfer caseAutimatic Transfer Switch?12 volt transfer pumpWater PumpAutomatic Transfer Switch (ATS)
