- ksssExplorer
45Ricochet wrote:
FishOnOne wrote:
ib516 wrote:
MARK VANDERBENT wrote:
Those duramax trucks seem to still match or beat the completion even with lower numbers. Sometimes numbers can be all hype.
Not if you check out any recent comparison tests. They are dead last.
The D/A combo is still a good one, but the power numbers need an upgrade.
Perhaps you should read this article.
That's the same company who handed GM "North American Truck of the year" last year, which GM uses in there ad's I might add :B
Nice and credible information from a a one horse publication. Clearly last year GM was last in power, last in interior and couldn't even participate in a real test like PUT.com did because of lack of payload for the big boy trucks :W
Looking forward to their new Colorado write up though.
OBTW that year of Ram 2500 didn't have the new Aisin tranny either thus less HP/TQ numbers.
Can't wait for a "real" test of the big three 350/3500's DRW's though.
Hope they can all make spec's this year, or do I need to wait till 2016-2017 :H
Ram has also had pull offs where they had insufficient capacity to compete in prior years. - ib516Explorer II
Good article, I always enjoy those comparisons! :)
Could be in those circumstances with those trucks. They tested 80 Km/h to 100 km/h acceleration with that load (horsepower predominantly), and used a 2500 Ram - which can only be had with the 370hp/800tq engine and 3.42 gears. The Duramax in that test would be 397hp/765tq and have 3.73 gears.
3500 to 3500, where the Ram has the Aisin and 385hp/850tq, the Duramax is left behind.
In the 2014 and 2015s, the Duramax is dead last...like I said.
VIDEO - 45RicochetExplorer
Hope they can all make spec's this year, or do I need to wait till 2016-2017 :H - Cummins12V98Explorer III
N-Trouble wrote:
Cummins12V98 wrote:
parkersdad wrote:
Buy a GM if you want but I have a feeling they are about to file bankruptcy again. Also they have been known to not back up there warranty. Who cares about these wars. My Ram has 370 hp and 800lb of torque. That is more than I need. They are going to keep on and these little trucks will have as much torque as a semi. Just crazy if you ask me. And by the way there is only one true diesel out there in my mind and it is an inline 6 called a Cummins. There is a reason they use it in the bigger trucks. Real diesels are inline 6, not V8.
Let's not forget the Cummins is a Medium duty engine and the other two are light duty.
Eeeh come on... And what exactly makes one medium vs light?
Duty cycle of 350K and the others are 250K.
Until 2015 Ford offered the Cummins NOT the Ford engine in their Medium Duty truck lines. I think they got tired of me pointing that out! - MARK_VANDERBENTExplorerThanks fishOnOne for that very recent pull off test. I did not read that one. Numbers being lower and that truck still can kick butt !!
- bogeygolferExplorer
macsplinter wrote:
I will keep my money and continue to drive an old 2005 duramax that is underpowered and out of date. If you have 65000 to 70000 to blow on the latest and greatest, be my guess. I need a good laugh.
Ditto. Our 2005 has been great, and virtually trouble-free. Heck, I'm still riding on the original brakes. And I can't imagine needing any more power than I already have. Great truck. ib516 wrote:
Perhaps you should read this article.- jus2shyExplorer
I used to believe this as well, but Ford really over-built the 6.7 for the most part. The Ford 6.7 has some pretty slick features that do make it medium duty and Ford is doing just that with their F650+ trucks using the scorpion motor going forward. I'm not as familiar with the Duramax's construction so I can't say much about it. But the Ford does a nice job using lifters with 2 pushrods to each unit so they have a bigger roller/surface area with the cam lobes. Also like the individual rockers for each valve as well in the head (no valve bridges. The reverse flow design makes great sense and reduces packaging. the Oil cooler is in an excellent location as well for servicing. The rods are a little small, even though H&S put a lot of power through the super duty, making power at relatively high RPM's is not as rough on a motor as low rpm lugging where the Cummins excels. So it's a possible weak spot for the motor. The main caps are pretty stout units as well. Bearings are also pretty huge looking in my book (another medium or heavy duty feature). The turbo was another weak spot, but it seems like this is resolved in 2015 going forward as well.
When I stared at a comparison video made against the Ford 6.7, I wasn't really impressed by what they defined as features that made their motor medium duty (seemed to be a dealership or something). It seems like Ford took all the short-comings of the 6.4 and applied most of them to the 6.7. I'd say the 6.7 is up to task. It will be interesting to see the new Duramax dissected in the near future. - MARK_VANDERBENTExplorerDuramax rules !!! Im just excited to buy an 01 duramax to get 300 hp and 520 ft pounds !!!!!!
- jus2shyExplorer
N-Trouble wrote:
Personally what I would really like to see happen in the HD diesel segment is improvements to the emission systems that are currently plaguing the reliability of these trucks as well as killing fuel mileage. Alternatives to DPFs and lowering the total cost of ownership of diesel engines would get my attention. A few more HP/TQ means nothing to me as I can easily get that and some with a tuner...
There is a lot that is currently being researched to get rid of the DPF. That's one of the big reasons for increasing the pressure to get that finer atomization and reduce the opportunity for particulate matter to conglomerate or form. I've also read up on Super-Critical fuel combustion, seems to have promise but there are lots of technical issues to overcome. The SCR system may stay as NOx is a bit tougher to control, but it is less instrusive to the tuning of the motor. I will be holding onto my truck until some sort of major advance comes to market.
44,052 PostsLatest Activity: Jun 10, 2015
