Crambo's avatar
Crambo
Going from a 205 to. 225 tire
I was fixing to order some new load range D tires the other day to replace the cheap load range C that came on the trailer. I just happened to stop by storage and I am glad I did before ordering tires. I was thinking I had 225 tires but they are 205. Now I am trying to decide if I should stay 205 or move up to 225. My wheels are lions head steel but I really don't know the width and it is a pain to take one to a dealer to pull a tire and check. It looks like I have the room to run a 225 but the rim width makes me wonder. is there even a need for me to go with a 225 on a 30 foot Coachmen Catalina that weighs in at around 6000 lbs dry?
  • If your rims are at least 6" wide, go for the 225's and load range E. It will give you confidence in your tires.
  • Check size of rim also, needs to be 6", I am considering the change as well
