Am considering installing two extra batterys an a 100 watt solar panel a top our Lance 881 . What type of controller an monitor would be needed? Any suggestations on the size an make of the inverter n...
If you go for a pair of 12 volt AGM batteries then running the microwave for short periods of time becomes possible. You would need a 2000 watt inverter.
I would suggest at least 60 watts of solar for every 100 amp-hours of storage.
