Am considering installing two extra batterys an a 100 watt solar panel a top our Lance 881 . What type of controller an monitor would be needed? Any suggestations on the size an make of the inverter n...
Pretty much need 2000 sine wave watts and four batteries to run the microwave. Probably more solar too.
300w will run the tv, satellite, dvd, laptop and charge small items. With <300w you can use existing battery connections and not pull wire. I recommend Go Power brand sine wave inverters.
