Am considering installing two extra batterys an a 100 watt solar panel a top our Lance 881 . What type of controller an monitor would be needed? Any suggestations on the size an make of the inverter n...
Have posted on this before but shall bore others again.
We have run the Dometic a/c on LFP/solar for 3.5 hours at a rate of about 1750 W. Our son trialed the system twice for 30 minutes running a/c and microwave simultaneously at a rate of around 3200 W.
Found out that the Dometic a/c may be a split level a/c heat pump. If so, then it will take a lot less power and can run all day on solar.
