6pac
Sep 03, 2014Explorer
Going solar
Am considering installing two extra batterys an a 100 watt solar panel a top our Lance 881 . What type of controller an monitor would be needed? Any suggestations on the size an make of the inverter n...
reed cundiff wrote:Hey Reed! Hope things are well with you guys!
Have posted on this before but shall bore others again.
We have run the Dometic a/c on LFP/solar for 3.5 hours at a rate of about 1750 W.
Our son trialed the system twice for 30 minutes running a/c and microwave simultaneously at a rate of around 3200 W.
Found out that the Dometic a/c may be a split level a/c heat pump. If so, then it will take a lot less power and can run all day on solar.
Reed and Elaine
