6pac
Sep 03, 2014Explorer
Going solar
Am considering installing two extra batterys an a 100 watt solar panel a top our Lance 881 . What type of controller an monitor would be needed? Any suggestations on the size an make of the inverter needed to power a microwave, TV , hot plate & diretv dvd? All suggestions would be appreciated.
After reading the responses of most we have discovered that it's not only possible but many have showed us how they've done their mods! Most use the ref vent to gain access to the inside of the cabin . Our Lance 881 doesn't have a ref vent, our ref is located on our slideout. We have a 55 watt located on the forward part of the roof , considering a 100 watt to be located toward the rear of the passanger side. To be mounted on the unistrut attached directly to the Maggie rack which will place the panel very close to the roof.( 11/2" above the surface. Also to readdress the location of the new two batteries ...they will be located on the driver side opposite the generator with wiring running across to the generator thus connecting all batteries together. The major problem we've found is how to gain access to the cabin. We're working on it!
