Golden_HVAC
Dec 22, 2015Explorer
If you are enjoying the stability in high winds, and ability to control sway really well with the 2,000+ pound pin weight of a fifth wheel, you might not like the in-stability of a normal travel trailer.
However a Propride hitch can correct those shortcomings, and add stability to the travel trailer. Having a 3/4 ton diesel truck to tow it will also really help too!
https://www.youtube.com/watch?v=rT268Y2ig_U
Look at the video, and see that there are a bunch of welded pieces there, and worth what they are charging for it. Then click on the cost of the hitch. Consider that most 30' travel trailers are a little less expensive than the fifth wheels of the same length. . .
http://www.propridehitch.com/products/ProPride-3P-Trailer-Sway-Control-Hitch-.html
Good luck,
Fred.
Good luck,
Fred.
44,066 PostsLatest Activity: May 13, 2026
