farmer's daughter wrote:
I'm new at rv-ing. Just bought a 24' Forest River EVO TT;
I have a 2012 Silverado 1500 4WD Crew Cab short box.
This has the 6 speed automatic, so a good thing
It's gear ratios are more suited for towing than the old 4 speed.
Type: six-speed automatic
Gear ratios (:1):
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Final drive ratio
(std. & avail.): 3.08, 3.23 or 3.42; 3.73 with Max Trailering Package
It has the tow package, Model K10543, 3.08 gear ratio, 5.3L V8. I I'm getting air bags installed on the truck tomorrow.
Note that this will NOT increase the ratings...just help level the
TV when loaded
Since 3.08 diff ratio, you do NOT have the Max Tow package. The
3.08 is a MPG ratio and is not a good one for towing, even with the
6 speed automatic. Consider changing that out, but with a 4x4, double
the cost, as the front diff also has to change...if you decide to
do this
Question? When I go up a grade, the engine gets loud and the rpm's jump up to about 4,000 before backing back down to 2-3. Should I be shifting down from drive to the next lower gear?
You have an "AUTOMATIC" and am assuming with the 'tow package' your
TV has the "Tow/Haul" button...use it, as it tells the computer systems
that it is hauling/towing.
So it will shift accordingly to protect itself.
You do NOT have to manually shift it at all, just engage the "Tow/Haul"
button and leave it to the 'automatic'
It will shift if it needs to and there is also a computer preset that
will protect your engine from over rev'ing
I don't have anyone to ask. (I'm a 63 yr old teacher).
Why I'm here on these forums...to help folks. I'm 68 and retired
after over 4 decades in the tech sector. Am a wrench/gear-head/boy-racer
since my first dealings with autos in my teens
Also, I am so confused by all the GVWR's/etc. My trlr dry weight is 5686, gross wt 7750. My truck was missing the sticker which told exactly what all it has, and in looking at the owner's manual it gives dozens of models. I finally found the model K10543 but still am not sure if I'm trying to tow too heavy of a load. A little late, now. The dealership assured me that it met the specs.
Here is the link to the GM Brochure with the specifications that will
help you in this regard:
GM 2012 Silverado brochureGood that this has the GCWR and here are the acronyms broken down:'
GVWR........Gross Vehicle Weight Rating
GCWR........Gross Combined Weight Rating (both TV and trailer's ACTUAL WEIGHT)
GAWR........Gross Axle Weight Rating
Note that the above has an 'R' and many either do not understand what
'rating' means, or do not believe it matters...but my opinion (having
been on the OEM side writing specifications, running product teams,
management of departments, etc) understand that it is the contract
from the OEM to you and the regulatory agencies that their product will
meet those ratings...within the bounds of the agency requirements
Forget about some of the brochure ratings, as they are derived from
'curb' and 'dry' (stripper models) that is misleading, but folks
thing absolute (in all cases) numbers. Depends on what options, after
market stuff and what is loaded onto/into
Here is the generic formula for GCWR >= TV + trailer + hitch +cargo
>= greater than , or equal to
Post back if you need more info...best to go out and weigh everything
ready go go...axle by axle...then post back here
