- sabconsultingExplorerOooo, a truck that folds for easy storage - clever :-)
Steve. - Gonzo42ExplorerNot to worry, that'll rub right out.
- Tom_BarbExplorerwell that's a chevy for ya
- Reddog1Explorer II
Raften wrote:
Geeze, it took 5000 pounds to break my frame, apparently just a camper shell was enough for that truck.
I will argue that the load had little to do with your frame or the frame posted.
Wayne - Buzzcut1Nomad IIhey back off, its just mid process into converting it to a redneck stretch limo...
- CayseaExplorerHi All
The mechanics said they would add air bags and that would fix this slight leveling problem. :h - ScottGNomadJudging from the wheel opening, it may have had a lot of rust.
- HalmfamilyExplorerThe good news is your front and rear uspension are fine. We found the reason why your truck was vibrating at speed. It may take a few minutes and a smidge over the quote we gave you to repair it. :S
- BedlamModeratorWhy didn't GM use that one on the rigid frame test they stream?
- The_Mad_NorskyExplorerWow!!!!!
With all the rust one can see around the rear tire wells, guess the frame was gone too!
44,056 PostsLatest Activity: Nov 19, 2013
