Camper76
Sep 16, 2017Explorer
LarryJM wrote:Camper76 wrote:
I'll be towing a Jayflight slx 294 qbsw. Dry hitch weight is 780, trailer dry is 6480, Gvw is 8250. I want something a little bigger just so I won't need to buy another one if we ever get bigger trailer.
Since you obviously have something now that you're using
1. What is it
2. Get to a set of scales and get some REAL NUMBERS and not those useless "DRY" ones you are now using.
3. Depending the min would be around 1200 with a probable end one in the 1500 range, but those are TOTAL GUESSES at this point. But what you now have is a fairly heavy trailer already so not sure how much heavier especially hitch wise you could get.
Larry
I have Reese with tounge weight of 1000lbs and 10000 gross. It has sway arm so I can't back up with it. Also I'm towing with ram 1500 hemi not sure if that helps
44,071 PostsLatest Activity: Aug 16, 2026
