ktmrfs
Sep 16, 2017Explorer III
like others, my dry tongue weight was laughable. around 800lbs, spec'd and measured with the empty trailer leaving the lot. Actual tongue weight, after I loaded it up, filled the propane tanks, added batteries etc. etc. is 1350lbs with an EMPTY fresh tank, 1500 with a FULL water tank. almost double the dry number.
on a TT figure at least the weight of batteries 70-140lbs + propane 60lbs or so will the the minimum you add to tongue weight. they are close enough to the tongue that virtually all the weight ends up on the tongue.
44,071 PostsLatest Activity: Aug 16, 2026
