MM49
Apr 16, 2014Explorer
intheburbs wrote:
I was just reading a thread about tires, and decided to go out and check the date code on my tires, to see when they were manufactured. I bought them last November from the local Goodyear store. Goodyear Duratracs, LT245-75-16. They've been great tires and they did well on our trip down to Alabama in late December.
Well, I go outside to look at the date code, and I notice next to the date code this nugget: Load Rating C :E
The Duratrac is marketed to commercial snowplow fleets. I didn't even know they made it in a "C" load rating. So I look up the specs - max load 2205 lbs @ 50 PSI. Well, the door tag on the Suburban says 50 PSI front and 71 PSI rear. On top of that, my rear axle weight on the Alabama trip was 5200 lbs. So I drove 2000 miles with overloaded, overinflated tires. I'm so mad I can barely type.
Yes, it may have been an honest mistake, but that wouldn't have mattered if we had a blowout doing 65 through the hills of TN or KY. I inadvertently put my entire family in danger.
I'll be going to the Goodyear store tomorrow to get a new set of tires for no charge.
Check your tires. Make sure they are the correct load rating.
I believe that you have legal standing in this case. The tire dealer is not permitted to install tire that don't meet the minimum requirements.
I think that you will find that the dealer will do back flips for you. Most likely you will get free tires an upgrade also. This is serious for a tire dealer.
MM49
