- bighatnohorseExplorer II
Powelligator wrote:
Great answers! :)
Fords are different from Dodges when it comes to the combination GPS Navigation and the Satellite antenna for the Sirius Radio. Dodge uses two different antennas (GPS is in the dash under the front window) and the Ford Super Duty trucks, 2013 - 2015 use a single dual band antenna which is mounted on the roof. By the way, Ford uses Sirius, true XM band radios are different (as found in gm products).
Yes, the cabover will block the Sirius signal, but not the GPS signal. I did a writeup on how to relocate the dual band antenna on a late model Super Duty, it's in one of the threads here someplace...
Joe
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27593249/srt/pa/pging/1/page/2.cfm - PowelligatorExplorerGreat answers! :)
Joe - trail-explorerExplorer
2oldman wrote:
Put a piece of foil over it and see.
Tin foil works well, for blocking aliens from brain scanning...mutliple other things too
- 2oldmanExplorer II
does the gps in a 2015 f 350 use the xm radio antenna for its signal? - n7bsnExplorerIt depends on model year, I couldn't find a reference for the 15's but for most years it's external to the GPS, but buried just under the dash.
I did find references to campers blocking it. - Super_DaveExplorer IITo my knowledge, the antenna is internal to the GPS unit itself.
44,056 PostsLatest Activity: Jan 12, 2020
