- drsteveExplorerThat is too much trailer for a half ton truck.
- ScottGNomadWay, way, waaay too little truck.
- mboppExplorerSeriously undertrucked, especially if your 1/2-ton is a crew cab & you're hauling a family.
- bailer6334ExplorerI have a Grand Design 2150RB and the published tongue weight is 485lbs. My actual tongue weight is 750lbs (2 propane tanks, 2 batteries & WDH). So the published weight is misleading. Can you pull it "YES". Will you be over on 1 or more rating for your truck most likely. Will it be a enjoyable towing experience? Probable NOT.
Remember its 35ft 11inches long! - DinTulsaExplorerYou will be over a rating somewhere for sure, most likely payload or receive hitch rating. With the right setup hitch wise you can probably tow it safely, but I would imagine that there will be some white knuckle moments. That's a lot of trailer for a half ton, what gears does your truck have?
- APTExplorerI estimate that's over 8500 pounds loaded for al long weekend with 1100 pounds of TW. Few half tons can handle that and not exceed one rating or another with a family in the cab. Payload, rear axle, and receiver ratings should be verified in addition to tow rating.
44,056 PostsLatest Activity: Jan 12, 2020
