Ralph Cramden wrote:
All of that said I looked over my friends closely, and have looked at many on lots and at shows. I see no difference in materials, workmanship, and methods from a lot of other brands. Plenty of loose trim, sloppy cuts, spaghetti wiring, sloppy work in general. And like most others lots of Lippert...maybe more than average.
And I'm going to call BS on this - I'll go as far to say big pile of BS...  We went to several dealerships and then to a RV show where several vendors like Jayco and Grand Design were present.  The difference in materials used and fit and finish were very obvious.  There is no loose trim, spaghetti wiring or crappy fit and finish.  Coming from a Coleman Travel Trailer, I have a lot of experience with these issues.  Most units I went into smelled like formaldehyde.  Jayco Eagle was on our short list.  We ended up buying the Grand Design as it was vastly superior to the Jayco .  I can go into it in the summer heat, after it's been closed up awhile and notice that its significantly cooler.  It has a new car like smell - still does.  And yes, you can call them out on the Lippert frame, but talking with the people on the
Grand Design Owners Forum, I was convinced that if I did have an issue, it would be corrected to my satisfaction.
These issues it seems are molehills made into mountains.  Problems reported on other forums are't corroborated by actual people who own the product.  I've owned my GD 303 RLS fifth Wheel since the beginning of the year and have used it several times.  There is nothing that is broken, needs to be fixed or isn't working as designed.
But like I have said, you need to go into the Imagine and see it for yourself.  compare it to what you have seen and have been into.  Join the GD owners forum - there is a specific area for Imagine owners.  You will be able to get good information on there - no one says things like everything out there is junk.  If you listen to people on here, you will just forget about RVing and buy a pontoon boat - can't say many negative things about a pontoon boat...
IMO, It will be worth your time to drive there.
