Upon sight of one, it appears that it’s square and rigid and wouldn’t conform to uneven surfaces but the joints have enough flex that it actually does work great on odd ground.
I can tilt my camper forward backward or sideways like a ‘64 Chevy on hydraulics.
I’d rather off-road with the Stable-Lift than with corner jacks. Over the years I’ve ripped out a corner jack or two, but the Stable-Lift can take a pretty good hit with no issue.
It sits about as high as my axles do.
Of course for ultimate clearance you’d have corner jacks and remove them from the camper.
It’s got three little turnbuckle stabilizers that literally drop into place if you want it totally rigid while off the truck. Drop those on and give ‘em a twist or two and it feels like the camper is on a concrete foundation.
Anyway... if the loading/unloading difficulties are a big concern, these things are the solution.
As far as backing under the camper straight, you’ll have to do that with any setup and that’s a matter of learning how to drive your truck. It’s got mirrors, that’s what they’re for.
