ajriding's avatar
ajriding
Explorer II
Jan 23, 2019
Gray tank under truck
Anyone ever put an extra gray tank under the truck?
I removed all my holding tanks, and will not use them til I re-sell it. They block too much, the spare tire thing, the license plate, the air bag valves and the trailer hitch.
I usually boondock and can drain gray to ground, but sometimes need a small tank. I dont do toilets.
I have room under the Ram passenger seat for a decent size tank. A garden hose will suffice to get it there.
  • To answer your question: Look at mounting a 6" or 8" pvc pipe about 5' long from the hitch or even in a hitch cradle. A 6" piece 5' is about 4.8 gallons. My father had an 8' piece mounted under the wing of our old Franklin for the kitchen sink.
    But if it was me, I would do the following and use the camper tanks:
    Spare tire cable retractor can easily be fixed by rotating 90* so it can be accessed from the wheel well. just have to remove 4 small bolts, rotate and then re-install.
    License plate usually isn't really blocked since it can usually still be seen when sitting in a vehicle 3 vehicle lengths behind the truck. My tag has never been real easy to see since even my father's old Franklin, but I've never been stopped by the police except when I pulled out too close in front of one so had to get on the throttle and released so much soot he had a black cloud to drive through.
    Air bag valves can easily be relocated. They are usually plumbed to behind the fuel door to give them a little protection.
  • I have thought about installing a "saddle tank" under the sides of my truck so I could transfer waste without taking the trailer anywhere.
    Seems like it would work.
