opnspaces
Feb 13, 2021Navigator III
Dusty Boots wrote:
Yes, this is the manual I have. Black water not overflowing into the shower drain when full. Must have a flapper valve in-between to separate the 2 tanks. When I get home I will flush and empty the Black water tank, open the cap and valve. Fresh water into sink should flow out w/o backing up???
Leave the drain hose connected so you don't wind up with a mess. Just pick up the hose in the middle and you'll feel it filling up with water and getting heavy. Then just set the hose down and let it drain out into the sewer.
