AnEv942
Feb 13, 2021Nomad
A lot of sites list the Sixpac grey and black tank capacities as 38 gallon for each-however its the same tank.
Why there is a separate monitor for 2 waste tanks puzzling-unless they are measuring also same tank, one stuck? Cant imagine though 2 sets of sensors (what usually fouls) on same tank. Could mark, switch leads on monitor see if it changes, if it doesnt change monitor suspect, if it does change not sure what that would tell, your still at square 1.
If there was some kind of one way valve on grey line it could be stuck- but capacity would be severely limited as only be between in pipe?
Never heard of one, sounds like a good idea.
But simplest, Id also empty tank, pour measured amount down grey see if it comes out.
