sbodi4d's avatar
sbodi4d
Gray water separate connection on Pup
Got the High Wall delivered yesterday, and noticed the black and gray connections are separate, and the gray is much smaller. Is there a hose made for this size connection? I have looked on CW, but can't find anything, maybe I'm missing something...
  • RoyB's avatar
    RoyB
    Explorer III
    My 2008 OFF-ROAD POPUP only has the one sink producing GRAY WATER and did not come with an internal GRAY or BLACK WATER Tank. Only a 30-dallon FRESH WATER tank.
    guess the PUPs doesn't have a too big WATER CONFIGURATION to support all of the things the bigger trailers have....
    Even my fresh water tank has a manual fill port not like the auto fill some of the bigger trailers have.
    Everything water wise on my POPUP is pretty much manual operations it seems.
    This is a typical WATER CONFIGURATION for my POPUP and is low key as compared to the larger trailers... The shower connections shown here are the built-in CASSETTE POTTI/SHOWER combo unit. The CASSETTE POTTI has its own built-in 6-gal tank for flush Water and an additional pull-out tank for the BLACK WATER produced.
    This is a typical WATER CONFIGURATION for the larger trailers
    You might be able to re-configure some flow paths since you have a GRAY WATER and BLACK WATER TANK...
    Roy Ken
  • Thanks for the info, that's what I was looking for. I do have 12 gallon black and gray holding tanks. So much for flushing the stinky slinky with the gray water...
  • RoyB's avatar
    RoyB
    Explorer III
    This is what I use for my GRAY WATER dump. I connect a short cut off water hose to the drain connector and let it fill one of my two 7-GALLON AQUA-TAINER water totes. When one fills up I switch the hose to the second tote and haul the filled AQUA-TAINER tote to the rest room and pour down the drain there.
    I have a two wheeled folding cart to haul the heavy water totes with...
    My trailer dows not have a BLACK WATER connector as it uses a CASSETTE POTTI which has its own 6-gallon black tank that has wheels. When this fills up I tote it to the bath room and pour down the toilet there...
    Photo from GOOGLE IMAGES
    Roy Ken
