JohnG4706
Apr 08, 2015Explorer
Disinfecting Water Connections
I just purchased a new TT and haven't used it yet. I know I have two available water intakes.
With the city water connection, do I need to disinfect it and the kitchen and bath faucets? If so, how? I also have a Watts pressure reducing valve and a two canister water filter system that I will use when on city water.
I have a 51 gal fresh water tank. How do I disinfect? How much water do I need to use to fill and flush the tank? What type of bleach can I use? Regular laundry bleach? What is the ratio of bleach to water? How do you add the bleach to the tank? Is there a special valve or filler that I need to use. How long do I need the bleach/water in the tank before flushing?
I have a brand new water hose. It too has never been used. I am thinking that the hose should also be disinfected? How? Suggestions? I will connect the male to female ends of the hose together after the hose is disinfected to prevent contamination after cleaning.
How often will I need to disinfect during the camping season?
I have read that when making the hose connection to the city water I should use a bleach/water solution in a spray bottle to sanitize the hose bibb. In addition, I should use a fresh solution since the bleach will lose its effectiveness over time.
Thanks.
Thanks.
