B.O. Plenty wrote:
I don't know what difference it makes. No matter which hose you use, they are both connected to same spigot for the water supply. What am I missing here?
B.O.
The difference is normally 10 to 20 feet of hose. The female end of the hose never comes in contact with the connection to the sewer flush. If you use the same hose the male end of the hose moves from the sewer flush connection to the fresh water connection. Much more likely to transfer contaminates.
One thing I did to my black water flush system was add another check valve right at the hose connection. My original setup had a check valve installed near the tank. When I would disconnect the hose, I   would get a small amount of back flow. I know this was water that never made it into the tank or even past the original check valve about 10 feet away. But I still didn't want it flowing into my wet bay.
