cmarkj
May 03, 2014Explorer
cmarkj wrote:
I will be as brief as I can be. I just bought a Denali 289RK. It has 2 gray tanks (one up front and one in the back). The one in the back is for the kitchen and has its own dump valve. The one up front is for the bathroom and is tied in with the black tank.
Normally when the black and gray tanks are tied together, the gray ties into the dump line down stream from the black tank valve so you can dump the gray if it is full and the black tank can stay isolated (correct so far??)
The under carriage of the Denali is all sealed so I can't see what is going on, but I know one thing for sure right now......in order to dump my front gray tank, the black tank is dumping right along with the gray tank. The gray tank is tied into the dump line up-stream of the black tank dump valve, not down stream to be able to keep the black tank isolated.
I really hope I haven't confused everyone, because I need some help. If this is designed this way, and not a build screw up, all their engineers should be fired.
Their paperwork says that the black tank level should be at least 3/4 full before dumping the tank. The way it's set up now, if the gray is full and the black is at 1/4, the black is getting dumped way too soon
Please help me......
A quick update....an update: brought TT to a local dealer, pics were taken and sent to the factory. A valve was installed on the black tank line upstream of the gray line tie-in. Picked it up 2 days ago and now that's it's no longer raining cats and dogs, it will test it to make sure it was all done right. (Everything was done up inside of the enclosed undercarriage).
Thanks to all that responded.
44,052 PostsLatest Activity: Oct 29, 2025
