Flatfive
Aug 12, 2016Nomad
Greasing wheel bearings
Our 2002 Fleetwood Prowler has two axles but no Zerk fittings for the wheel bearings. There is a large axle nut with a cotter pin. I guess to properly grease the bearings I'd have to remove the nut and pull the wheel off (wheel puller required?). Then apply grease and replace the seals and then the wheels and nuts. I'm on a big road trip (6 months so far). Today I removed the grease caps and filled them with grease. Then I pushed the caps back on and tapped them in place with a hammer. My question is: did this do any good at all? Where can I take it for a proper grease job?
