imq707s's avatar
imq707s
Great.....my "new to me" 2011 TT has a rotted spot in floor!
I recently picked up a nice 2011 Crossroads Zinger 19RDS TT. Before I bought it I walked around on the floor checking for any soft spots, checked the inside and outside of all the walls, looked in every storage area and checked for signs of water, inspected the roof for any bad spots, checked all of the caulked joints and seals on the outside of the trailer…..and aside from a little waviness of the front outer “hung wall” on the nose of the trailer, everything looked great! The previous owners took really good care of it ….and never really used it much.
Fast forward to last night…..I pulled out the rear bench/couch in order for my wife to get to some areas that she wanted to paint. And what do I find? The rear corner of the TT that was covered by the bench, was spongy…and after cutting out a piece of linoleum to inspect, is completely rotted out. At least it’s in a spot I can easily get to in order to make the repair. It should be an easy fix, I’ve done this type of work before.
There are two things that boggle my mind……1.) Where did this water come from? All the seals look great, the roof looks great, no delamination of the fiberglass walls on the outside of the trailer, and there is nothing in that area on the outside of the TT that would lead me to think water was getting in. 2.) This thing is only 5 years old……are these TT’s really put together so badly that only after 5 years, they leak bad enough to have a part of the floor rotted out!! I can’t imagine what I would have been in for if I would have bought a TT that was 10-15 years old.
  • If it's near a window, I would check the seal on the window where the window frame meets the siding on the trailer. I had a couple of windows that the chalking around the frame had cracked at the top of the window. The water would follow the frame to the bottom and then run down the inside of the wall and puddle on the floor.
    I resealed all of the window frames.
    Also check under the trailer to make sure the membrane isn't torn or missing and allowing water to spray up
