- kohldadExplorer IIIDon't worry about it unless you are trying to do a good cleaning flush. I often dump with the front lower due to dump station designs which only means I don't get a complete dump. To make matters worse, my tank is a flat bottom tank. Have over 500 nights with over 150 dumps without a problem or buildup.
TCCamperNoob wrote:
Thanks. Can you all recommend a light set of blocks for this amount of weight?
Any style of stackable RV leveling blocks will work. I use then or pieces of 2x8- jaycocreekExplorer II
- MORSNOWNavigator III
I always carry various lengths of 2x6's for under my tires, under the jack bases, and can be split with a hatchet for starting the campfire. They are lightweight and can fit in many small spaces around the camper and truck. - Geo_BoyExplorer IILynx Levelers.
- TCCamperNoobExplorerThanks. Can you all recommend a light set of blocks for this amount of weight?
Bedlam wrote:
You can always drive up on blocks with the front wheels if you want better or faster draining at the dump.
This is what I do. My truck also sits tail high.- BedlamModeratorYou can always drive up on blocks with the front wheels if you want better or faster draining at the dump.
- TCCamperNoobExplorerthanks
- srschangNomadDepends which direction the outlet comes out of the tank. Most tanks have a molded in downhill to the drain. In the large scheme of things, a gallon left in a tank after you drain doesn't really matter.
