gkainz's avatar
gkainz
Black tank dump plumbing replacement?
My kids got a used RV and on their maiden trip discovered the black tank dump plumbing leaks. Appears to have one or more cracks in the plumbing from the tank to the dump valve. They tried to patch it with flexseal to get them through the weekend but didn't stop the stinky drips.
Taking a quick look at the dump plumbing, it appears to be a series of 3 or 4 elbows from tank to dump valve with little to no pipe sections that could be cut and new elbows glued up to replace the cracked section(s).
How does the first fitting secure into the black tank? I didn't notice any flexible type seal or joint and a hose clamp, but again, was just a quick look, not a close inspection. My fear is that this first fitting is glued into the tank outlet?
Thanks for any suggestions! I intend to manage this repair and give my son-in-law instructions from a safe distance :)
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 23, 2025
