opnspaces
Sep 15, 2013Navigator III
Rebuilding or replacing a valve is fairly easy. It's only 4 bolts and the old one is off. You could probably pull the old one, spot whatever is keeping it from sealing, clean it, and put it back together inside of 30 minutes.
Oh here's a link to the twist on valve mentioned above. Link
You could put one of those valves on the end of the pipe and just not worry about the other valve at all.
If you have an enclosed underbelly you might have to either remove the screws around the perimeter and drop it, or cut a hole to get to the valve.
Good luck with it.
Good luck with it.
44,068 PostsLatest Activity: Jun 05, 2026
