Caboose66 wrote:
I have a 3-burner Camp Chef as well and I really like it. Haven't used the grill box a whole lot but have used a griddle directly over one of the 30K BTU burners a number of times - works like a charm.
One thing I am not entirely clear on, and was mentioned a post or two before this one... As long as I do not have a regulator on my LPG supply line or on-board the camp stove, I can plug right into the quick disconnect on the TT and be good to go... correct?
Camp Chef (and others) make a hose setup especially for this application. You remove the hose with the regulator from the stove and put this one in it's place. It's got the 1/2" (?) connection on one end to connect to the stove and the male quick-disconnect fitting on the other end to plug into the TT LPG supply.
Correct me if I'm missing something about this setup.
That is corect from what i have read.
