bkenobi
Apr 14, 2017Explorer
Ground power options
My NL TC has a 3 pin plug on it with an adapter to fit a standard 15A socket. When removed, the plug is a 3 pin 30A type that will fit into the generator socket in the bay where the cable is stored. My question is, is this designed to be used exclusively with a 110V twist lock type outlet or can it also be used with 220V? There isn't anything that I can see that specifies. I am assuming 110V only, but thought I'd ask a dumb question in case it's not so dumb.
The reason I ask is I'm going to add an outlet on the side of my house and can provide either 110V or 220V. If 220V works and would charge faster that would be good to know. If I'd burn something down, I guess that might be good too.
