colliehauler
Dec 25, 2014Explorer III
handye9 wrote:I have to agree. I own two Cherokee's that have served me well and would buy another. I would buy the one that works best for you. Maintenance is the key to a long life.
Long term will depend on how you maintain them. When you drag these things down the road, at 60+ MPH, things are going to come apart. Doesn't matter who built it.
Either trailer will serve you well, as long as it has propper maintenance.
One area I would be conccerned with, is the tongue weights and what you're towing with. The manufacturers are advertising both trailers as 1/2 ton towable. However, both of these trailers have "dry" tongue weights at or above 1000 lbs. There are many 1/2 ton vehicles that don't have the payload to carry that kind of tongue weight.
Trailers in the same price point will use similar construction components and materials.
I have owned 2 Gulfstreams and 3 Cherokees. The only one I did not care for was the Gulfstream Streamlite with the foam core floors. I traded after one trip. The two Gulfstreams you are looking at have solid floors and should be fine.
44,031 PostsLatest Activity: May 21, 2025
