hmknightnc
Jun 01, 2014Explorer
okan-star wrote:
How would he make it work and stay within the door tag?
He says his truck weighs 7800 lbs and his GVW on the door tag says 10100 that's a payload of 2300 lbs the camper weights 4000 lbs he says
The axle door tag is usally 2x the tire rating of the tire on the door tag ,he says its 6200lbs , no way his truck weighs 2200lbs in the rear
Pack light?
Pack helium balloons ?:?
Geez kind of an about face on your part isn't? You started with aftermarket tires are good so your good to now he needs helium balloons. WOW
No way his SRW truck actually weighs 7800#, my fully loaded dully with all kinds of******on it and in it weighs 7800# empty. He's probably around 7000# in reality with about 3000# on rear axle. With 6900# rating that leaves 3900# load available for the axle. Even if his guess of 4000# TC is right not all of that goes on the rear, some goes on the front.
He needs to actually weigh it to find out. He might make it he might not. It's going to be close.
44,066 PostsLatest Activity: Oct 04, 2013
