Same info from a rv.net member from BC who posted his findings;
(paste and copy)
dukesofhazzardcounty
British Columbia
langley
....well another phone call to a dot worker that I personally know,
here it is, go by the gross axle weight rating front and rear, tire ratings, and then make sure you are not over your licensed gross rating, ex. mine is 4600kg, he said after you get the camper and if you are under on the axle ratings and tire ratings but over the licensed gross rating, up your insurance to be over your total gross, this is the cash grab part of it, you are paying more for fixing the roads etc. the more weight you are. so there you have it from the bc dot.***
