drillagent
Mar 02, 2014Explorer
GCWR vs GVWR question
I know the weight topic has been beat to death on this forum, but I may have just come to a realization and after searching, I can't find the answer to my question. The weight capacities of my TV and 5th wheel are below. So here it goes.
From what I've read here and what I've been told by Ford, the weight ratings are based on what the vehicle can STOP. So going by the ratings below, my truck can STOP a 5th wheel that weighs up to 15,200lbs. Everyone talks about the GVWR and the pin weight.
Is the pin weight subtracted from the trailer weight? The pin weight is 2175lbs of the 12,201lbs trailer weight, right? So the truck is carrying 2175lbs, and towing 10,026lbs? I guess the real question is, if the GCWR is below the 23,500lbs weight rating, but because of the pin weight, is above the 10,000lbs GVWR but below the 6,000lbs GAWR, am I actually considered overweight when it comes to STOPPING the vehicle? When it comes down to it, just because I may be below the 10,000lbs GVWR, I've still got another 10,000lbs of trailer to stop. And if you do the math, with an 18% pin weight (based on Keystone website calculations) of the 15,200lbs TV capacity, there is no way you can be under GVWR unless you have a 160lbs driver with no passenger. So, does the GVWR really matter when I'm towing a 5th wheel or just when I'm hauling a load of rock without a trailer?
I have a 2012 F250 Diesel. All weights are per 2012 Ford towing guide or actual scale weight.
Truck weight w/o passengers 7100
GVWR 10,000
Max 5th Wheel towing 15,200
GCWR 23,500
Rear Axle GAWR 6,000
Looking at purchasing 2010 Montana 3750FLF. All weights per Keystone website.
Dry weight 12201
Hitch weight 2175
Carry Capacity 3474
GVWR 10,000
GCWR 23,500
Dry weight 12201
Hitch weight 2175
Carry Capacity 3474
