Supercharged111
Jun 09, 2013Explorer
GM GVWR/GCWR chassis/powertrain questions
Starting to do my research here, but it seems very few people ask the questions that I do. I'm indifferent to class A vs class C, I'm after something no bigger than 25' and I'm sure either can accomodate my needs as far as amenities go. I want to pull my car to the track as I do behind my pickup now, but this way to have a place to sleep if the weather is hot/humid, rainy, etc. This will also enable me to make this a family event and not just me disappearing for the weekend.
At any rate, onto the questions. I love to wrench, so that's what my questions are geared toward. What are the GVWRs and GCWRs of some common GM chassis? I'm inclined to thinking that the chassis are pretty much all the same, with a camper slapped on the back of a cutaway van (so the camper part is the variable). The Fords wear an E450 badge on the side, so they're easy to spot, but I'm starting to doubt GM ever gave up anything heavier than a 3500 chassis to a class C motorhome? I know they did 4500 chassis, but my fruitless google searches seem to indicate that they all went to the topkicks/kodiaks, and perhaps the class A motorhomes? If only a 3500 chassis, is that a 12,000# GVWR? What's a camper typically weigh? I don't want to cross the scales overloaded pulling a car trailer and I'm not looking at newer motorhomes either, just something new enough to have overdrive. I can get the power from the motor eventually, which leads me to my next question: when not pulling a car trailer, how well do these behemoths hold OD? I live in CO where the air is thin, and my truck needed a little help performing up here so I imagine an inverted sail is no different.
