I have a 1995 F-350 dually, door sticker says GVRW is 4500kg I'm not overloaded on axle weight but am on gross weight according to door sticker usually around 4750kg gross. My registration in Ontario ...
When I said axle weights I meant if they weigh you they will add up what your axles weigh and as long as you are not over your registered weight on the registration you will be ok door sticker does not matter at least not in Ontario or BC in Canada
