Good day!!! The D.W. would like me to hook up an H.D. antenna to our house using a travel trailer antenna. is this is possible, or will this work? I am trying not to run a cable from the existing...
A television is a television and an antenna is an antenna, no matter where they are installed. The only difference is the length of coax cable running from the antenna and the television. Also, if using in your house, you might need a power booster too (like in your camper... that little button you push where the antenna wire hooks into for the television.)
