Good day!!! The D.W. would like me to hook up an H.D. antenna to our house using a travel trailer antenna. is this is possible, or will this work? I am trying not to run a cable from the existing...
So you are just trying to avoid another antenna, right? That's a good idea if your RV antenna will get good reception in your location. Check it on the RV TV first. The main thing is to use high quality cable if you have a long run. The drawback is having the cable lying in the yard. (Of course you could always bury it. :D)
