Good day!!! The D.W. would like me to hook up an H.D. antenna to our house using a travel trailer antenna. is this is possible, or will this work? I am trying not to run a cable from the existing...
f you get good signal on your RV antenna, you can get a flat plate antenna at Walmart, BestBuy or Sams that will do just as good for your house. Just stick it up inside a window, and follow simple directions to connect it you your TV.
