bucky
May 02, 2015Explorer II
Prior to the TIPM designation, the same item was called a Forward Control Module. The units are subject to water intrusion under the hood and corrosion starts in the basement if you will of the unit. They have 3 major pieces. The lid, then the array of relays and fuses on a board, and then the most lower slice. That middle piece can be removed from the base piece, and that is where they often fail. We have saved some by cleaning the corrosion and or replacing a connector. never hurts to try.
44,068 PostsLatest Activity: Jun 17, 2026
